Brief Description: Mounted center harnes point brackets
I finish assembled the copilot side center harness attachment point brackets now that the parts are painted. When fabricating these parts, I discovered that I had put in two of the floor ribs in the wrong places. This caused the Van's kit not to fit entirely correctly. On the copilot brackets, I had to fabricate 6 spacers to attach the right side of the brackets to the rib using 6 AN3-10A bolts, washers and nuts. This is heavier than using the 10 blind rivets called for in the kit procedure, but should be as strong. On the pilot side, I had to remove the terminal blocks and trim switching relays to make room for the brackets. This will require rework of the wiring harness in this area.
