Laced up all the wires to be terminated to the main Skyview connector. This included power and ground lines, audio lines, serial lines, lightning circuit, and USB port lines. It's a pretty crowded connector. Had to share gound lines between multiple serial data limes. But it all came together. Assembled the shell and laced the wires back into the main bundles. Dressed the bundle up into the Skyview. The bundle has sufficient length to allow the Skyview unit to be pulled out and disconnected from the front panel.
