Brief Description: Mounted Skyview Modules and Ignition
With all the backing plates and mounting brackets painted, I completed the mounting of the SkyView EMS and ARINC-429 modules on the left side, the secondary alternator voltage regulator in the center, and the two light speed ignition system on the right side. I found it very difficult to get wrenches into the bolts on the SkyView modules and the ignition system boxes. I cut 1 1/4 inch sections of 3/16th inch tubing to act as spacers and extended the length of the bolts so they were more accessible. This adds some weight, but if I ever have to take these bolts out, I'll appreciate the addition.
