Brief Description: Prepared wiring harness for Garmin stack
I decided to rework the wiring harness that was attached to the Garmin equipment. I determined what sets of wires needed to be run together between the chasses and what sets of wires needed to be run to the left and right of the insturment stack. I needed to extend some of the wires to provide sufficient service loop lengths. I then laced up the bundles so that they would allow the chasses to be independently removed from the front of the panel. I then laced the external wires to points next to the stack and mounted Adel clamps to secure the wire bundles.
