After the snorkel cured, I tried to fit it up to the engine. I discovered that the section that I cut out of the snorkel had a twist in it. The twist was counter to the twist needed to mate up the snorkel, so I had to break the joint in order to redo it. I decided to make some measurements to determine exactly where the front end and back end needed to be. I set this up on the bench to see what had to be done.
