Air O Enterprises
Date:  5-29-2006
Number of Hours:  7.00
Brief Description:  Oil Cooler installation
Once the final location for the baffle plenum had been established, the final location for the oil cooler could be planned. I used 1"x1" square aluminum tubing to space the oil cooler back from the rear baffle plate by cutting it into a "C" channel, and installed it using rivots and nutplates. Once the oil cooler was attached, I fabricated oil hoses of the correct length and plumbed the oil cooler to the rear engine manifold.
Final oil cooler installation
