Air O Enterprises
RV-8
Main wing fitting
The wings were finally fitted to the fuselage using hardware store bolts per the instructions. Alignment for leading edge and incidence was CAREFULLY measured and then the trailing edge mount was drilled for final wing location.
Finished wing installation
RV-8 Home
1195
