Glareshield covering was installed from Cleaveland Aircraft. Covering included edge trimming that looked great. The windscreen was drilled / cleco'd into place and the windscreen frame was drilled and tapped for #6 stainless screws to better control the attach pressure. The inside of the windscreen was painted black around the edge mating to the fuselage as to hide external paint / fiberglass work. A bead of windshield urethane adhesive was applied to the windscreen frame and the fuselage and the winscreen was glued and screwed into place.
