Jan Hanekoms RV Web Site
ZU-JVR RV10
Terminal Strip and breakers
Measure out ad drill holes inUHVM strips.
Fit terminal screws.
Fit finished terminal strip to panel bulkhead.
Modify switch sub panel by making it shorter in order to fit properly.
Drill and fit plate nuts to switch sub panel.
Drill and fit three breakers not on switch sub panel anymore on RH side of lower panel.
Drill flap switch hole.
Terminal strip
Fitted
Three breakers moved
ZU-LOL RV7 Home
ZU-RVI RV10 Home
ZU-XOX RV10 Home
ZU-JRV RV7A Home
ZU-JVR RV10 Home
6382
Cooling Baffles
Cowling
Doors
Elevators
Fairings
910
Horizontal Stab
Instrument Panel
Rudders & Brakes
Systems
Tailcone
Test Flights
Trim tabs
Vertical Stab
Windows
Windscreen
