Jan Hanekoms RV Web Site
ZU-JVR RV10
Install Cabin heat tubes
Install Y on RH heat box inlet.
Connect two scat hoses tothe Y outlets.
Connet at cabin heat outlets front and rear.
NOTE: The LH outlet will be used to blow cold air into the tunnel.
Front
Rear
ZU-LOL RV7 Home
ZU-RVI RV10 Home
ZU-XOX RV10 Home
ZU-JRV RV7A Home
ZU-JVR RV10 Home
6382
Cooling Baffles
Cowling
Doors
Elevators
Fairings
910
Horizontal Stab
Instrument Panel
Rudders & Brakes
Systems
Tailcone
Test Flights
Trim tabs
Vertical Stab
Windows
Windscreen
