Jan Hanekoms RV Web Site
ZU-JVR RV10
Install steps
Clean hole and remove primer from the section that needs to slide in.
Slide steps in and matchdrill hole. Go up to 1/4 inch for an AN4-20A bolt instead of the AN3 as per plans.
Tighten and then prime cleaned sections with steel etch primer.
ZU-LOL RV7 Home
ZU-RVI RV10 Home
ZU-XOX RV10 Home
ZU-JRV RV7A Home
ZU-JVR RV10 Home
6382
Cooling Baffles
Cowling
Doors
Elevators
Fairings
910
Horizontal Stab
Instrument Panel
Rudders & Brakes
Systems
Tailcone
Test Flights
Trim tabs
Vertical Stab
Windows
Windscreen
