Jan Hanekoms RV Web Site
Date:  8-17-2012
Number of Hours:  4.00
Brief Description:  Repair HS
On close inspection it was found that there is one hole on the F-714 (angle) where a rivet has been drilled out and the hole did not look gooed at all. I am sure this will develop a crack later on.
The inbboard ribs were carefully removed and the rivets holding the F-714 drilled out.
A new F-714 was then manufactured.
