Again assemble per drawings , you make up some bushings for the side plates, and two elevator stop sleeves. Everything went smoothly until you try to install the tube in the aft bushing they give you on the cage. It's powder coated so I reamed it out, sanded the push pull tube, and assembled. You make a hole in flap mount tube to install the assembly
