Jamey&Ricks Rans S6S
Date:  7-2-2008
Number of Hours:  3.00
Manual Reference:  08-1 08-4
Brief Description:  Finish control stick assembly
Built up the control tee that goes on top of the cockpit cage as they call it, they have you assemble it, check for play , if there is none you install six rivets and install. Next grab all the parts for the pulley assemblies, lot of different nut bolts and washers, so be careful, I use little plastic trays to separate the parts. There is two u brackets that get bolted together, with the nut fits snug inside, its kind of tricky to tighten, I used a pair of needle nose to hold the nut. After you build them look at the fig 8-8 for reference and they installed just fine, Run the cables install the turnbuckles, and tighten up per instructions. Next push-pull tubes
