What a day! Paul Cox came to help out. First we leveled the RV. Then filed and lubed the inboared wing spars. Then we installed the left wing. It went in when the dihedral was positioned correctly. The right wing went in a lot easier. I set up the plumbobs while Paul and Steve measured thethe wing/tail/cockpit. Next we set the inceidence for the same unit on both wings. All measurements were wiyhin 1/16 of an inch. We drilled the aft attach point starting wita a # 30,# 12, then The final 5/16 and installed the AN-5 bolt.Broke for lunch. Next, we strightened the roll bar and drilled it to the RV.The C-804 canopy slide was measured and attached to the center top of the fusellage and drilled.Finally we cut the left flap 4 times to fit and installed.
