Brief Description: Continued engine accessory installation.
Paul and Steve drilled several holes in the firewall for fuel and heat box. They installed the propeller govenor,fuel pressure manifold line and the VA-168 port. the VA-168 is the port for the fuel,oil and electronic ignition. Oil cooler lines were installed but more AN fittings are needed to complete the installation.
