JIM'S WEB SITE
Date:  2-23-2006
Number of Hours:  12.00
Manual Reference:  8-17DWG27
Brief Description:  Completed elevator @ rudder control
INSTALLED THE ELEVATOR AND FILED THE HS-603 LOWER EDGE SO THE ELEVATOR HORNS CAN GO 30 DEGREES NOSE DOWN. FILED THE F-812 SO THE ELEVATOR CAN GO 25 DEGREES NOSE UP. DRILLED THE 4 HOLES IN THE RUDDER HORNFOR THE TAIL WHEEL SPRINGS AND THE RUDDER CABLE. INSTALLED ALL FITTINGS FOR THE RUDDER AND ELEVATOR AND THEY WORK OKAY.
