Brief Description: Built F-8103 Latch Assem+Elevator pushro
Made spacers from the ab4-188x1 1/4. Cut clevis pin . Primed parts.Drawing 46.Started F-635a elevator bellcrank. Made spacer(F-635b) and drilled rivet holes.Prefit VA-146 bearing assembly.to plates .Primed all parts(Drawing 26). Sized F-841and F840 elevator pushrods and completed riveting of one rod end bearing.
