Jaco Swanepoel's KR2S Web Site
Date:  7-31-2004
Number of Hours:  9.00
Manual Reference:  Dwg 23-37 Tri-gear
Brief Description:  Nose Gear
I purchased a front shock absorber of a 125cc motorcycle and modified it to become part of the nose gear. I replaced the internal coil spring with a specially manufactured dia. 5mm wire coil spring from Pretoria Spring Services. The sleeve was welded back up and machined.
MODIFIED 125CC MOTORCYCLE SHOCK ABSORBER
