I disassembled the existing manifold in order to re-use certain pieces. I constructed a new inlet manifold and machined the openings where the injector sleeves were to be welded in. I also constructed two fuel rails to be fitted above each row of injector. The two fuel rails are connected with with a steel fuel line.
