Jaco Swanepoel's KR2S Web Site
KR2S
Dwg 23-37 Tri-gear
Aliminium Brackets
I finnished all the machining on the different mounting bracket components that I received from Clyde Engineering and took it to Central Welding Works to be assembled.
NOSE GEAR BRACKET - 6MM ALIMINIUM
MAIN GEAR BRACKET - 6 MM ALIMINIUM
MACHINED ALIMINIUM SHAFT WITH STEEL CASTLE NUT
KR2S Home
977
Ballistic Parachute
Cowling
Fuel Tanks
Instrument Panel
Under Carrige
KR2S Home
