I stripped out the trim tab control cable and fittings. I used a hole saw to make a hole on the lower surface of the elevator, in line with the trim tab arm. I used epoxy glue to fit a PVC enclosure in which I will fit the servo. I used the cable opening in the horisontal stabilizer to draw through the electrical wiring for the servo.
