Brief Description: Clecoed the Flaps Trailing Edge Wedges in Place
Clecoed the Flaps Trailing Edge Wedges in Place after applying a thin layer of tank adhesive to the wedges. The previously match drill aluminum angles were clecoed to the trailing edges for straightness.
Drilled #33 the holes in the bottom skins for the blind rivets. Attached the bottom skins to the ribs with the blind rivets.
Applied weight to the flaps to keep them flat on thework bench surface.
