Brief Description: Riveted the Flaps Top Slins and Nose Skin to Spar
Riveted the Flaps Top Slins and Nose Skin to Spars.
Checked the flaps for twist by measuring the angles of the hinges to each other. This was a bit confusing. In the cradles, there was an instability in the vertical positioning. If there is a difference in the angles. ten you are supposed to twist the spar to reduce the differneces. Once equal, there is no twist in the flap. I decided to lay the flaps flat on the table then measure the hinge angles. All of the measurements were close, no need to twist the spars.
Riveted every tenth hole then randomly riveted the remaining holes.
