Brief Description: Started the Installation of Wing Wiring Harnesses
Started the Installation of Wing Wiring Harnesses.
Installed the Lights Wiring Harness in the Left Wing. I labeled the wires with shink tube labels. The outboard spar has a holder into which the harness connector is supported to insert. The holder is shaped for something other than the connector that is supplied with the harness. I can modify the holder by filing the opening to fit the connector but I am first asking others what they have done.
Installed the Autopilot harness in the Right Wing. Again, the molex connector of the inboard end of the harness did not fit the holder. This time, I filed the holder to shape to accept the connector.
