Brief Description: Blind Riveted the Flaps Nose Skins to the Nose Rib
Blind Riveted the Flaps Nose Skins to the Nose Ribs after drilling the holes out with a #33 bit.
Match drilled a length of aluminum angle to the trailing edge of both flaps. This will be used to insure the trailing edge is as straightas possible while the trailing edge wedges are adhesed ot the top and bottom skins trailing edges.
