Brief Description: Drilled Holes and Installed Snap Bushings
Drilled Holes and Installed Snap Bushings for the Pitot Tubing Run Through the wing to the bay outboard of the Aileron Bellcrank. I had already used the holes with snap bushings that were installed earlier in the construction. I used them for extra wire runs for future uses.
I drilled 3/8" holes for the snap bushings and the ID was 1/4" for the 1/4" plastic Pitot Tubing.
