Brief Description: Added An Extra Set of Wiring Holes in Both Wings
Added An Extra Set of Wiring Holes in Both Wings because I ran out of options for adding or replacing wired in the wings because some of the installed snap bushings are full. By adding another run for wiring, I am able to significantly increase the number and types of wiring installed in the wings. I called Van's before installing additional holes in the ribs and they don't thing that there are any issues. The holes were made using step drills and, in certain ribs, a 1/2" drill bit. The 1/2" drill bit gave me the reach needed to drill the holes in ribs inaccessible to the step drill bit. Appropriate snap bushings were installed in the holes after deburring the holes.
