Brief Description: Scratched Lead Edge Parts For Priming
Scratched Lead Edge Parts For Priming. For whatever reason, the ribs of the leading edges were in sad shape. There was something black stuck to just able a good portion of each rib. Tried solvent to removeit but it was essentially ineffective. Scotch brite pads barely touched it. I used a green 3M Roloc Brissle Disc with good results to remove the black marks and corrosion while producing a good surface for the primer adhesion.
