Brief Description: Removed the Aieron Twist in the Left
Removed the Aieron Twist in the Left.
On the suggestions of VAn's Tech Support, I made a pair of V-Cradles similar to the ones used during the construction of the RV-8A's control surfaces. Then, one of the cradles is clamped to the bench while the cradle on the opposite end is used to apply the torque in the opposite direction of the twist to remove the twist. After an initially weak attempt to remove the twist, the second attempt resulted in a very good match of the e=angles at the ends of the sileron. Success!
