John (Jack) Clark's Web Site
RV-14A
Assembled the AHRS Tray Per Instructions
Assembled the AHRS Tray Per Instructions. Match drilled the Base Plate to the Lower Wing Stiffener - Short. Disassembled parts for priming.
Drilled the #19 holes in the Lower Skins for nutplate installation.
Deburred the holes drilled.
Added a slight bend to the inboard edges of the outboard lower skins so they will lay flat when riveted together.
RV-14A Home
3573
Aircraft Related
189
1351
1351
RV-A8 Home
