Brief Description: Bolted the Right Fuel Tank to the Spar
Bolted the Right Fuel Tank to the Spar. As expected, The installation of the bolts was much easier to align with the Z-brackets when the tank was not secured by all of the screws. So the trick here is to install the bolts first and the screws later.
Used the wrong washers with the bolts. Will replace tomorrow.
