Brief Description: Fluted the W-1008 and W-1009 Leading Edge Ribs
Fluted the W-1008 and W-1009 Leading Edge Ribs.
Modified two W-1009-L Ribs and two W-1009-R Ribs so that they conform to the stepped construction of the Wing Spars. An aft portion/portions were removed ribs was removed according to the plans. This created the now labeled W-1009-L-1, W-1009-L-2, W-1009-R-1, and the W-1009-R-2 Ribs.
Dimpled the #40 holes of the ribs.
Dimpled the nutplate holes in the W-1008-R Rib. Drilled the Screw Holes to #19.
