Brief Description: Drilled Out Bad Rivets In Left Spar Top Skins
Drilled Out Bad Rivets In Left Spar Top Skins. Replaced rivets and applied rivet tape. I plan to try riveting with the backplate in place on the table and the top skins on top of the plate. I'm looking for a good way to back rivet solo.
Installed the rivets in the rear spar top skin holes then applied riveting tape.
