John (Jack) Clark's Web Site
Date:  3-10-2012
Number of Hours:  3.00
Brief Description:  Configured the EIS and GRT HX EFIS Displays
Configured the EIS and GRT HX EFIS Displays. Each piece has its own configuration and then there is the integration configuration between them. Lots of manual reading and referencing. Much of the fine tuning of the equipment will come with use. Some parameters are hard to set without actual flight experience in the aircraft. Others are straight forward with expected flight performance data and limits from the aircraft builder's manual.
