John (Jack) Clark's Web Site
Date:  8-15-2011
Number of Hours:  2.50
Brief Description:  Finished Pitot/Static Installation To the EIS
Finished Pitot/Static Installation To the EIS. I received the NyloSeal connectors that accept the 1/8" NPT ended 5/32" nipple connectors used to connect silicone tubing to the two Static and one Pitot ports on the back of the EIS. These ports are used to display an alternate source for Airspeed, Altitutde and Vertical Speed on the EIS or the EFISs.
Used two bulkhead fast connectors and two right angle connectors to pass the pitot and static tubes throught the bulkhead forward of the EIS. A 1/4" nylon tube connects from here to the NyloSeal end opposite of the nippled end.
Pitot/Static Through Bulkhead
Connections Aft of Bulkhead
Silicone Tubing to EIS Nipples
