John (Jack) Clark's Web Site
Date:  7-9-2011
Number of Hours:  3.00
Brief Description:  Cut the Panel for the ELT Remote Panel Control
Cut the Panel for the ELT Remote Panel Control. I constructed a template for drawing the lines for the rough cut, used a Dremel cutting disc for the big cuts and a grinding tip for the short side cuts. The edges were filed to fit for the ELT Remote Panel Control. The attachment holes were match drilled. After all was fitting properly, the panel was touch-up painted.
Hole Cut
Hole Cut
Panel view
Panel view
