John (Jack) Clark's Web Site
Date:  3-22-2011
Number of Hours:  1.50
Brief Description:  Installed an Inline Fuse for the Fuel Guardian Lig
Installed an Inline 0.25A Fuse for the Fuel Guardian Lights at the Instrument Lights Dimmer Terminal Strip.
Soldered a 47 ohm resistor inline for the Master Warning light that comes off of the GRT EFIS. If my math is correct, this will limit the current to a max of 0.2A as required by the stated limit. The light is being run through the Instrument Lights dimmer so this max should not be seen in normal circumstances.
Soldered inline 47 ohm resistor
Shrink Wrapped Resistor
