John (Jack) Clark's Web Site
Date:  3-19-2011
Number of Hours:  1.50
Brief Description:  Ran the Pitot/Static Lines for the Avionics and Ao
Ran the Pitot/Static Lines for the Avionics and AoA. The pitot line is a 1/4" O.D. blue nylon tube and the AoA lines are about 1/8" nylon tubes, one blue and one clear, both of which come from the left wing root area. The lines run through the left side of the center spar, along the left side of the forward cabin, up the forward cabin bulkhead and across the brace behind the panel to the right side of the panel. The small AoA tubes are passed through a grommet placed in the aft baggage compartment wall and then attached to the AoA computer nipples for each tube.
