John (Jack) Clark's Web Site
Date:  1-27-2011
Number of Hours:  3.00
Brief Description:  Cut the Upper GRT HX Opening in the Panel
Cut the Upper GRT HX Opening in the Panel. I used a Dremel Cutting Disc and files guided by a steel angle iron fence secured along the desired cut line. Each cut in the panel makes you fear that you are going to wreck the panel. But I must say, I am happy with the results.
