Brief Description: Fabricated the Transponder Antenna Doubler Plate
Fabricated the Transponder Antenna Doubler Plate. The antenna will be under the passenger seat on the right side. This measured to just over 6 feet distance from the transponder installation. The antenna is supposed to be mounted greater then 3 feet but not much over 6 feet from the transponder using the RG-400 coaxial cable.
Dimpled the Left Forward part of the Bottom Tail Skin that underlays the Flap Fairing after the holes were deburred.
Primed the doubler plates and the step where it had been welded to increase the clearance of the left rudder cable. Prior to priming, I applied a corrosion converter on the steel that was welded, both inside and outside.
