John (Jack) Clark's Web Site
Date:  2-16-2010
Number of Hours:  1.00
Brief Description:  Wired Servo outputs from the terminal strip
Wired Servo outputs from the terminal strip. Was going to wire the External Starter button on the grips but discovered a conflict with the Vertical Power plan. Will contact VP for a solution.
Trim Output terminal
VP CU Cable wired
VP CU Cable wired
