John (Jack) Clark's Web Site
Date:  12-30-2009
Brief Description:  Made cables for the Aft Ground Terminal Block
Made cables for the Aft Ground Terminal Block. This included putting a terminal on the #4 Tefzel cable coming from the Forrest of Tab and terminals on the #4 Welder's Cable from the Block to the Brass Grounding Strip of the Battery Tray.
I re-routed the Auxillary Battery Control Switch wire to the area on the left side of the instrument panel. This wire will be connected to the Auxillary Battery Contactor Control Switch of the Vertical power Switch Panel. I ran another 20ga. wire from the Switch Panel area back to the Auxillary Contactor where it was connected to the Contactor.
Terminals on cables of block
Ground Terminal Description
Aux Bat Contactor Control Wire
