John (Jack) Clark's Web Site
Date:  12-3-2009
Number of Hours:  1.00
Brief Description:  Electrical planning
Electrical planning. Plan to change the way that the #4 cable from the Main Battery Contactor is routed to the power lug of the VP CU. I will be incorporating a Terminal Block to distribute power to the VP CU and to a Fused terminal block. The fused terminal block will give me more options for running power wires independent of the VP CU. I should be able to use the fused terminal block as a means of trickle charging the batteries in the future.
