John (Jack) Clark's Web Site
Date:  12-28-2009
Number of Hours:  2.50
Brief Description:  Fabrication/Installation Aft Grounding Block Mount
Started with 1" x 1" aluminum angle and formed a Grounding Terminal Bar mount that was attached to the right Baggage Compartment rib after surface conversion. The mount was light weight and strong.
Surface converted mount
Attached mount
Attached mount
Ground Terminal Block installed
