John (Jack) Clark's Web Site
Date:  6-20-2009
Number of Hours:  3.00
Brief Description:  Attached 200A ANL holders to platforms
Attached 200A ANL holders to platforms.
Crimped and soldered lug terminals to the first of many #4 welder cables. First, I used a sharp ravor to cut the insulation about 1/8" longer then the cable band on the terminal. Using 1/4" solid copper 18 AWG wire pieces that were made pointed, I added four pieces to the center of the cable wires to make the cable fit snugger in the terminal lug. The lug was placed in a hammer crimper and hammered to the #4 indicator. After a pull test the terminals were soldered using Rosin Core 60/40 solder. Dual wall shrink tubing with the adhesive on the inside was heated to the terminal for mechanical stability of the terminal and wire.
ANL fuses bolted in place
Hammered Cable Crimper
Crimped/Soldered/Sealed
