John (Jack) Clark's Web Site
Date:  4-2-2011
Number of Hours:  1.50
Brief Description:  Checked and Corrected Heater Fan Wiring
Checked and Corrected Heater Fan Wiring. When I checked the fan switch, the high and low positions were reversed. The easy was to fix this is to change the positions of the High and Low wires on the switch. But since I had labeled the wires, this solution would just result in wire confusion in the future. I tried to switch the wires at the Molex Connector by the fan but I had the harnest time removing the pins. In the end, I removed one pin and pulled out two wires without pins. I started over, re-crimped pins on the wires and correctly inserted the wires into a new female connector. The results were that the heater fan now works as it should on Low-Med-High positions.
