John (Jack) Clark's Web Site
Date:  11-12-2010
Number of Hours:  3.00
Brief Description:  Re-laced the Right Side Wires that Needed It
Re-laced the Right Side Wires that Needed It. Installed self-stick ziptie mounts that will be used to secure the laced wires as the run forward. I am allowing at least 24 hours for the mounts adhesive to strengthen after application.
Re-routed the ADS-B power wire. It was initially ran on the right side for the EIS. The EIS is now coming off of the Fused Terminal powered by the Backup B switch and power wire. Now the wire runs along the left side and terminates in front of the ADS-B box.
Self-stick ZipTie Pads Installed
Split tube on laced wires
View of the Right Front
