John (Jack) Clark's Web Site
Date:  7-6-2009
Number of Hours:  1.50
Brief Description:  Installed the Rudder Cables
Installed the Rudder Cables. Ran the cables through snap bushings in the bulkheads. Installed the F-805E Rudder Cable Supports after surface converting, priming and adding nutplates. Anchored the plastic tubes that prevent the cables from rubbing on the adjacent foot wells by carefully drilling a #21 hole in the plastic tube then inserting and Zip Lock through the hole. The Zip Lock is secured around the F-805E Cable Supports.
Hole drilled
Hole drilled
Zip Tie through the hole
ZipTie secured around support
