John (Jack) Clark's Web Site
Date:  4-13-2012
Number of Hours:  1.00
Brief Description:  Installed Bolts in Right Side Pedal Adjustment Hol
Installed Bolts in Right Side Pedal Adjustment Holes. Bolts, Washers and nuts can be installed in the adjustment holes ready for future adjustments. A spacer was added to the bolts to facilitate tightening the unused bolts. Now, when the pedals need to be moved, a wrench can be inserted to hold the bolt head and the bolt does not have to be removed to adjust the pedals. Each location on the right side has pre-installed hardware.
Top Down view
Top Down view
